Pixhawk CW motors overheating problem
I've guys this is my first discussion here so first of hi to all
I've a strange issue that make tho motor 3 and 4 (CW motors) very very hot
If I see the logs I can see that they in hovering output high pwm values than others. So I searched the web and I've found this guy with the same problem as my but the solution discovered didn't work for me (Adjusting the PID's).
I've made all this things to try to fix this problems but none of them has worked:
Calibrating accelerometer, compass
Motor/compass calibration
Swapped one motor
Changed one esc
I have used extra weights to improve CG balance
These are my quad specs:
Frame f450
Motors 4x sunnysky A2212 + 4x 1045 prop (balanced)
ESC 4x 30apm simonk
Pixhawk + ublox m6
Telemetry 3DR radio
Battery 5000mha 50c
3DR power module
I've attached some logs
This is an example of pwm output
3691204764?profile=original
Sorry for my bad english
16.BIN
17.BIN
19.BIN
  • @Stefano Finocchiano. My quad same error, pls show me How.to fix it
  • are the propellers the same type/manufacturer/pitch ?
    two of them are supposed to be "pushers" ( have opposite direction or rotation)
    - are *all* mounted the same way ? (for example with text/size information "up") ?
    and all rotate like : http://copter.ardupilot.com/wiki/connecting-the-escs-and-motors/  ?
    we assume your hot motors are hot because of higher power(producing more thrust) - because you've tried to swap them, and eliminated bad motor widings/magnets, bearings etc.
    The only way 2&3 (clockwise) rotating motors can produce more thrust while in hover with no yaw is:
    1: if 1&4  performs very differently, (other propellers)
    2 if 1 or 4 are mounted on a round arm, and are slightly "rotated" , so they are not pulling only up, but also creating a yaw that 2&3 needs to counter.
    or in other words: if 1,2,3,4 consumed the same amount of power , had same props, and gave equal thrust, you would have a fine hover - if 2,3 actually works harder as it seems, - it should have yawed all the time, if the power/thrust was the same for all motors.
    • Thanks a lot, I sloved. The problem was a slightly rotated motor! :)
  • Deleting the profile. Excuse me. For leaving that out
  • Have you tried the profile from your hand held transmitter then re binding the two?
    • I've tried to held the copter in one hand but to get motor outputs leveled I had to rotate slowly CCW (to help CW motors)
Liam left a comment on Agricultural UAVs
"Hi
I'm Liam from T-MOTOR. I would like to reach out to see if there is any possibility for us to work together.
We are a propulsion system manufacturer who offers motors, propellers and ESCs for all kinds of drone applications which vary from secur…"
Richard Cox left a comment on Australia
"Anyone in the DIYDRONES Australian subgroup based in Alice Springs, NT?
I am experimenting with Ardupilot (standard Arduplane), Pixhawk 4 FC in a 4-ch
RC "AXN Floater Jet" foamy plane..."
Jun 29
Omar Sykes left a comment on Australia
"Hi everyone, I am looking for someone who is good at drone building, repair and software in Adelaide. Please give me a call on 0477 319 219."
Jun 29
