I'm trying to set a Pixhawk with dragonlink and Dx8 for adruplane. After connecting everything I realized the channels need to be remapped (Went to Full parameters list, then entered 3 for RCMAP pitch, 2 for roll, 1 for throttle and 4 for Yaw).
And channels now corresponds correctly to switch movements. BUT failsafe doesn't work as it should, it works kind of inverted. When throttle stick position is in lowest 150% then I got normal control of servos & flight modes when in reality this should trigger the Failsafe. In any other position of the throttle stick on the DX8 then it stays in failsafe.
Anyone have set this combination (DX8, pixhawk, dragonlink) successfully?
HI Andrew,
still have that problem. I'll try connecting pixhawk to DL receiver like conventional way, using PPM encoder and see what happens. Maybe should we post this somewhere else to get more replies? I'm pretty sure someone have solved this before, let me know
