My Pixhawk boots fine when powered by the power module only, but when I connect 5V to the servo/motor output rail, it doesn't boot but just makes clicking sounds instead.
Video demonstrating the problem:
https://www.youtube.com/watch?v=jODj9UzkG1Q
The 5V being supplied to the servo output rail comes from a J&K Universal Power Distribution board with built in 5V and 12V regulators. I measured the 5V regulator output to be 5.00V exactly on my voltmeter.
If I connect the 5V to the servo output rail after booting, then it works fine too.
My wild guess is that it's a timing issue at power up, e.g. if one of the power inputs get's power a before the other, then the Pixhawk freaks out.
I tested it with a different 5V regulator afterwards and then it did boot. But that doesn't explain why it doesn't boot with the power distribution board's regulator.
Mine was working fine when all of a sudden it stopped booting and is making the crickets sound. I did try to plug it in with a 5V power instead of the USB into my computer
James said:
The crickets sound is probably (my guess) the power input selector switch that can't make up it's "mind" about which input to use resulting in the Pixhawk not booting.
I did get the crickets sound a few times with my LC filter too, so I switched to a different 5V regulator and so far it's working fine. I did report the issue to 3DR long ago, but haven't received any feedback/help so far, even though I'm using original 3DR hardware.
Any luck James? I was flying fine yesterday but today my Iris+ gave a low battery failsafe beep when plugged in via usb. I unplugged and plugged back in, now I only get "crickets". No led, no beep, only clicking. Scared to plug battery in. I would really like to hear from someone who has ID'ed the clicking sound first.
Update:
Because I suspected it has something to do with the sequence at which the power module and the UBEC for the servo rail reach their full voltage (5V), I added an LC filter after the UBEC to slow it down. If I do that, then the PixHawk does boot.
I'm not one of the lucky few who own an oscilloscope, so I can't analyse in detail what's going on/wrong, but hopefully somebody can figure it out.
B.t.w. it can't be an initial voltage spike, because I'm using a 5.3V zener diode between the + and - rails.
Update:
Even just adding a 6.3V 220uF capacitor over the main output rail is enough to make it boot.
