PixRacer with Ardupilot
This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens.  Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
3691274249?profile=original
  • The Micro/Pixracer is getting better but its very bouncy if I come out of a fast run and let go of the sticks.
    I tried autotune but could not get it to start.
    I tried using Ch7, in MP when I select autotune it does not highlight, so I tried using the one in flight modes and but it never started the autotune either.  If Autotune should work, so far have not been able to do it.
      Hi Edgar,
      I normally just set CH_7 to autotune in the advanced parameter list. Then enter Alt Hold and make sure your sticks are in the centre and the altitude isn't changing.
      If your autotune doesn't start then let me know and give me the dataflash log and I can tell you why.
    • T3
      Edgar,
      I have not tried autotune with 3.4dev so there might be some other problem but make sure you are in AltHold before triggering Autotune. Also I think (not 100% sure if required) that THR_MID must be set properly and you should be in the dead zone when switching to autotune..
  • I think I set mine to 13.69 voltage divider and 48.19 Amps per volt.  It seem to checkout ok after looking at the logs.
    I wonder if the 3DR version works better or if its the Pixracer?
    Anyone try the ACSP5 version?
    • I use the ACSP5 in my micro, the ACSP4 was too big
  • Now that more people are using this, have other people noticed the current reading from the ACSP4 is wrong?
    Or the curve is wrong, or something?  It's correct over a range.. But then lower and higher readings are off.
    Basically, I have to have my multiplier up to about 200 to get a reading at idle (w/ all my FPV and recording gear it's consuming about 700ma at idle).
    Then w/ the suggested setting(I think it was about 36, going by memory) it's correct in the 10ish amp range.  But then it's not right over that.
    I saw one person post the other day that they didn't get a reading until pulling some amps, and suggested "it's not meant to be a low power current meter", but other power modules are...  at least, I do get a reading at idle on my other copters w/ different power modules.   If that is the official answer, I'd like to know.. then I'll stop worrying about it.
    Edit--  I haven't played w/ this in a couple of weeks, and I see a lot has changed!!  So, not sure if this was addressed or not.. I'll have time to play and test it tomorrow :)
    • It should register but not be very accurate at lower currents (my 3DR styles ones were anyway) -- like all these shunt based modules. I will dust off my ACSP4 and test it next week. I have been using Mauch power modules that I picked up and have not used my shunt based ones any more.
  • Any chance that we could get UAVCAN to work with Zubax GNSS2. Pavel sent me a patched APMv2 for pixhawk to get me working on that platform and I would really like to try the Zubax with the racer. It is really a sweet GPS unit, would be great to have it fully functional on the APM side.
    Great work on the racer, many thanks to hardware and firmware developers.
    Cheers, R
      As far as I know the latest UAVCAN is in master.. so I would have though that Copter-3.4-dev would work.. I guess it doesn't?
