PixRacer with Ardupilot
This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens.  Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
3691274249?profile=original
                • Hi Cala,
                  The same with my Frame F550, Mots 2212/920 (original DJI) 1.8 kg
                  Hoover with 45%
                  Has nothing to do with oneshot or hight kv motors.
                  I will post it on the recommended link.
                  Otto
              • Another 2 Pics
  • With MP Beta it was possible to increase the Params.
    But now with the same Params and Frame as with Pixhawk and FW 3.3.3, the behavior is verry strange in Loiter Mode.
    Even with 9 Sats and hdop 0.9 it moves around slowly in a range of 10 m, +/- 5m Altitude and up to 30° Yaw.
    The Vibs are lower than 9. Hexa F550, 1.8 kg, 3S. Pixracer R14, FW 3.4-RC1
    https://storage.ning.com/topology/rest/1.0/file/get/3702258676?profile=original
  • BTW.. is there a pin supporting a sonar module producing pwm/analog signal? TY:)
  • Checked my spektrum satellite and Pixracer's RC_INPUT with a logic analyzer. What i noticed is the INPUT pulses slowly. If i connect the satellite, i cant see any difference. But.. if i power the satellite alone, it produces some sort of a fast serial transmission on its data port.
    Am I using the wrong port or need to change some params?
    (see images attached about logic analyzer screenshot)
  • Pixracer, AP 3.4-RC1 MP 1.3.38 Param Issue
    In MP Config/Tuning-Extended Tuning the Values for Rate Roll/Pitch can no be increased above the default Values (P 0.135, I 0.090, D 0.0036)
    It is possible to recuce it but not increased.
    May be the defaults are enoughe high for Racers but not for a F550 with 2 kg.
    My values with a Pixhawk and the same Frame are P 0.18, I 0.18 and D 0.0145.
    • I have trouble w/ the tuning screen at times, too.  But if you enter the value in the full parameter list, it will work.
      • With beta, work's
      • Hi Scott W, thanks for your reply. I will look for it in the list.
        Does the Tuning with Poti on the TX Ch6 work?
    • Did you update M Planner to beta?, if not, try that.
