PixRacer with Ardupilot
This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens.  Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
3691274249?profile=original
  • Thanks Otto
    I know about PixRacer GPS port pinouts. I made a special cable for Pixracer GPS Port, so I can connect GPS and PX4FLOW module. I tried connect i2c external led. It's work fine. I think cable don't have any problem.
    Can I use nsh mode to get list of connected i2c devices?
  • @Denis,
    The description (5V,SCL,SDA,GND) ist a I2C Port on Pixhawk 4 pins, The GPS is connected to a serial Port (RX,TX) on Pixhawk or Pixracer 6 pins. On Pixracer the GPS Port is combined with RX/TX and SCL,SDA on a 6 pin connector.
    Denis said:
    Thanks Marcell
    Today I tried connect PX4FLOW to a GPS port (5V, SCL, SDA, GND)
    I use this manual: http://ardupilot.org/copter/docs/common-px4flow-overview.html?highl...
    Parameters:
    FLOW_ENABLE = 1
    LOG_BITMASK = 131071
    My problem is that dataflash logs not contained OF message’s
  • Thanks Marcell
    Parameters:
    FLOW_ENABLE = 1
    PX4FLOW Optical Flow Camera Board — Copter documentation
  • Hi Denis,
    By the release notes, it should work, at least on an experimental level.
    See https://github.com/ArduPilot/ardupilot/blob/master/ArduCopter/Relea...
    I wish i could answer this question based on practical experience with px4flow ;)
    Denis said:
    Can I use PX4FLOW with a PixRacer(AC3.3.4)?
    ArduPilot/ardupilot
    ArduPlane, ArduCopter, ArduRover source. Contribute to ArduPilot/ardupilot development by creating an account on GitHub.
  • Can I use PX4FLOW with a PixRacer(AC3.3.4)?
  • Status update. Seems the issue is introduced in px4firmware. Baro and accep seems to be conflicting. After a few try starting /reseting baro, it starts providing data, but accel stops working (mpu6000). Reproducible with px4 latest beta and master and 3.4rc1 and master. Havent find any related commit yet. (This is still the ugly clone. Genuine is on its way to me)
  • When I'm setting HIL_mode to 1 and restart my Pixracer, my radio is not recognized anymore?!?
  • Wow, thank you very much! Excactly what I was looking for. :)
    @Tobias,
    Pixracer is a FMUv4 board, so you need "make px4-v4" instead.
    Note that you don't need a special firmware for HIL in plane, just set the HIL_MODE parameter to 1 in a normal firmware.
    Also, HIL isn't really very good for simulation, SITL is much better. For planes you may like to look at a posting I did recently on using SITL with X-Plane 10:
    http://ardupilot.org/dev/docs/sitl-with-xplane.html
    Cheers, Tridge
    Using SITL with X-Plane 10 — Dev documentation
  • Hi, what command do I need to make a firmware for Pixracer? With make px4-v2 and trying to write the firmware to the Pixracer, MP tells me, an Error: Firmware not suitable for this board.
    In fact, I'm trying to make a HIL-firmware to play a bit around with missions, without risking my plane or copter. :)
    Kind regards
    Tobias
Monday
Azjeg liked Azjeg's profile
Apr 27
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
