PixRacer with Ardupilot
This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens.  Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
3691274249?profile=original
    Copter-3.3.4-rc3-pixracer is now available through the mission planner's beta firmware link.  Only one change compared with the previous version (Copter-3.3.4-rc2) which is the parameter fix.
    If this version tests out well then we will make it the official version in a day or two.
    Thanks for your testing especially to Scott W who uncovered the issue!
    • Hi Randy,
      My latest version of MP does not show 3.3.4-rc3 in Beta Firmware section.
      3702619649?profile=original
      I had to load 3.3.4-rc3 manualy using load custom firmware. Saving parameters seems to be working fine.
      I could not calibrate accel. After pressing Calibrate Accel got quickly all this lines you see below:
      3702620083?profile=original
      Also, after booting Pixracer, the blue LED close to USB port is not blinking (it is OFF).
        Although it says "APM:Copter V3.3.3-rc2 Quad" if you look at the very top of the mission planner (in the screen shot above), you'll see that it's actually loaded Copter V3.3.4-rc3.  The discrepancy happens because we've got two different versions of the software in the beta area.  So the regular Pixhawks are on V3.3.3-rc2 but the pixracer version is running ahead to V3.3.4-rc3.  MP can't show both unfortunately perhaps because it doesn't actually check what board is plugged in until the vehicle icon is pushed.
        During the accel calibration it may have been working correctly but you were perhaps not able to see the messages because other messages were also being sent out from the flight controller.  I was able to do an accel calibration just now.. perhaps just do some of the other calibrations (RC, compass, etc) and then come back and do the accel cal last.
        • I was a bit confused reading your previous post but now everything is clear regarding version.
          Regarding accel calibration, I will do this step at the end, doing first RC, compass, etc, and see what will happen.
    I have pushed a fix for the parameter corruption problem to ArduPilot master. Randy is preparing a new beta release now that will have the fix.
    Hi All,
    I have reproduced the parameter corruption issue on my Pixracer. I can confirm the problem does happen with master, not just the beta releases.
    I have also reproduced the problem with px4 master, so the problem is not ArduPilot specific (I have given instructions on how to reproduce on px4 master in the PX4/Hardware gitter channel).
    I am working on narrowing down the issue. I have shown that the issue only happens with the ms5611 baro driver is started, which points the finger at a likely SPI bus corruption problem (as the ms5611 and FRAM storage are on the same SPI bus on Pixracer, a key difference from other boards).
    These types of issues can be quite tricky to track down, but I will see what I can do.
    Cheers, Tridge
    PX4/Hardware - Gitter
  • I follow with attention this thread because I have a pixracer in mind for build a 250 racer cuad, what esc are you reccomend for this little guys?
    sorry the OT question.
  • I ordered one for my Sub250 gram Micro, I will post when its complete and feed back on how it works on a very small copter
    • Speaking of light weight copters, I'd suggest they ship the PixRacer w/out the servo headers soldered in place. It's much easier to solder than to de-solder.
