This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens. Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
Phillip I really appreciate your responses and support! I want to get Pixracer but I see in website it is written that R14 will be released. does it mean that R12 or below versions have flaws or are not going to be supported completely in future? When will final design units be ready for sell?
Thanks Phillip!
You can install px4-v4 (Pixracer) with APM Planner 2.0.19-rc5* (OSX version here) or withQGroundControl**.
*linux and windows versions to follow, but can be build from source
** I know it works with master, not sure if the build as the code in, i'll check
From all us Mac users... Thanks Bill!
PhillipK from AUAV.co and I spent some time to narrow in on the issues with ardupilot and PixRacer, in particular the most serious issue is this "Bad Gyro Health" message that appears intermittently. It may happen more or less with Copter-3.3.3 vs Copter-3.4-dev but it can certainly happen with either firmware.
What we see so far is that IMU1 is appearing as unhealthy in the logs even though it is actually returning data. So you can see in the graph below that IMU1 is reporting gyro and accel values but the GyrHlt and AcHlt column is all zeros.
So we don't have a solution yet but we're on the case and it's a very high priority to get this sorted out.
Ah, I've created a couple of issues here and here to capture this problem and also a report from PhillipK that the SBUS input isn't working.
Not sure if this is a different issue, or same that Randy has already seen, ( He mentioned Master having this problem), but I have not been able to get any APM software to load on my Pixracer using QGroundcontrol or Mission Planner, including using the latest MP and Beta MP. I have tried both “Beta” and “Default ” loads in MP, but Pixracer will not see any radio on calibration screen (Genuine Futaba SBus Tx-Rx). Other calibration setup functions seem to work OK in MP after loading. I tried disabling all Failsafe’s in MP, but MP won’t see radio input. Bars on radio cal Screen just go blank with no movement and will throw an error if you click complete.
Should I try setting the Min RC failsafe value to some minimum number-even though I already have the radio FS box disabled? Currently it’s at 950 as that is what my other FC’s RC failsafe’s are set at, and I just copied the other APM profile to a new model on the Tx.
PX4 Stack seems to load/work OK using QGroundcontroll, but haven’t flow yet due to Flight Mode selection issues. (I never used Q till now and discovered late yesterday that Mode selection is keyed only to pulse width and must follow a specific order; so I think I need to reprogram my FG8 Ch5 Mixer to get Manual/Stabilize to kick in at proper pulse width so I can arm- I think).
Trying to load APM via Q seems to throw an error on some size parameters missing while downloading, but then seems to load FC, sensors calibrate Ok, but same issue – won’t see Sbus radio input with APM loaded.
Joe,
I haven't personally tested it yet but someone else has reported that SBUS isn't working with APM/Pixracer. Getting Pixracer sorted is definitely very very high on our to-do list.. just having some troubles juggling priorities to get these niggling issues sorted out. I really hope we can do it this week.
106
107
108
109
110
of 110 Next
