Please check out my graphs ....Moon gel
Hi everybodyyyy…..
More alt/hold questions. I have quadcopter with APM2.5 running 2.91
Here 2 graphs 1 with moon gel 1 without .
This is with moon gel
    3691004542?profile=original
This without
3691004551?profile=original
Does the graph with moon gel  look OK ?
And if it does  look ok can someone help me with the Barometer test in APM.
When I run it ,lots of number fill the screen and the test seems never to finish  ?
Is that right ? and if so how do I know if the results are good ?
Lastly (for  now)  with the moon gel fitted to the APM2.5  the quadcopter  when in ALT/HOLD
Slowly rises  . Where do I look next to fix it ..
Cheers darren
  • the graphs you are all posting - is this of hovering? or actually flying around?
  • T3
    You moon gel looks good. If your copter climbs when in alt hold, you need to set THR_MID to match your hover position on your throttle. Keep in mind the default is set at 50% and there is a deadband space about +- 10%.
  • MR60
    Hello Darren,
    On the graph with moon gel, we do not see the scale. Can you zoom so we see the exact deviation of the accelZ ?
    A good anti vibration system makes max plus or minus 2/10 of a G (a graduation is 1/10th of a G).
    Your graph seems to be bigger deviations.
    The best system has been tested many times : first a suspended plate (o-rings), then the APM with moon gel (or ear plugs) at each corner on this suspended plate. I reach in flight with unbalanced props max acceZ of plus or minus 1.5.
