please help... suspect broken imu?
Hi guys...
This was not working, was working and now isn't working
I'm using APM v1.0 beta
When I connect the board up I get the usual
Init ArduPilotMega 1.0-BETA
freeRAM: 4051
MSG: <startup_ground> GROUND START
MSG: Demo Servos!
<startup_IMU_ground> Warming up ADC...
MSG: Demo Servos!
MSG: Demo Servos!
<startup_IMU_ground> Beginning IMU calibration; do not move plane
  <startup_IMU_ground> Calibration complete.
MSG: <startup_ground> NO airspeed
MSG: reset_control_switch0
Now the telemetry the roll is all over the place
+++ASP:0,THH:14,RLL:1,PCH:0,***
+++ASP:0,THH:14,RLL:0,PCH:-5,***
+++ASP:0,THH:14,RLL:3,PCH:0,***
+++ASP:0,THH:14,RLL:10,PCH:15,***
+++ASP:0,THH:14,RLL:16,PCH:12,***
+++ASP:0,THH:14,RLL:11,PCH:6,***
+++ASP:0,THH:14,RLL:13,PCH:1,***
+++ASP:0,THH:14,RLL:6,PCH:-7,***
+++ASP:0,THH:14,RLL:-5,PCH:-5,***
+++ASP:0,THH:14,RLL:-21,PCH:9,***
+++ASP:0,THH:14,RLL:-30,PCH:17,***
+++ASP:0,THH:14,RLL:-35,PCH:19,***
+++ASP:0,THH:14,RLL:-32,PCH:28,***
+++ASP:0,THH:14,RLL:-56,PCH:43,***
+++ASP:0,THH:14,RLL:-70,PCH:40,***
WHen I move the board I'm not getting sensible results
Also I've hooked this up to HappyKillmore and the planes is spinning in the picture as expected
This was behaving like this then seemed to come alright but now I can't get it to stop
Is there something up with my X-Y sensors?
thanks
ryan
  • Went back at it with the soldering iron and fixed a few suspect solders
    and hey presto its working
    Thanks fro all the help guys
    I'm really enjoying this project...
  • another issue...
    when I do the dipswitch settings I'm having some issues with that too
    I get this...see attached
    very strange too...
    the dip switch is not moving
    debug2.txt
    https://storage.ning.com/topology/rest/1.0/file/get/3692138515?profile=original
    Run the CLI tests to narrow down the issue and post anomalous results here. Also, I note you're using old software. Please use 1.0 (not beta)
