  • Thanks all for the replies :)
    Just added some explanations about IMU pins to our repository..
    This should clarify few issues. Number after pin name is IO pin number in Arduino.
  • http://diydrones.com/forum/topics/open-pins-on-apmoilpan
    im not sure either. If you only need 8 more in/ouputs use the ones broken out onto the oilpan described by Jani. If you look at the eagle files, there seem to be a good number of pins that do nothing but connect the APM to the Oilpan (AN 8-15). I assume you could put stacking headers and use them as well. But I dont have any official confirmation on that. If you need more than 16 pins, you could also interface any I2C device to add pins through the I2C bus
    Simple question, simple answer: Yes :)
    Ok a bit more detailed answer. Basic quad uses only OUT0-3 pins, hexa will use OUT0-5 pins and we plan to use OUT6-7 to servo controls for camera etc.. OK in quad we can use 5-6 to something else. Now on latest AC codes we just have been using OUT5-7 for LEDs but they will be moved else wehere.
    Then you have all AN0-7 free to use. AN0-5 can be found on top of main APM pins eg next to relay. Next to relay will be battery measurement inputs so don't use those. Leave at least 2 voltage dividers free. Then you have two divider slots free and after that 3 normal AN inputs. I've been thinking to use those last 3 ones for in future to drive LEDs so if you don't want to have LED's at least they are safe to use and then you also have AN6-7 at center area of IMU board that are free to use.
