I've already burnt out one ESC trying to get airborne, which is to be expected powering 4 servos + GPS, but while bench testing my new 3A uBEC today, i noticed it was getting fairly warm (and that was just with ArduPilot+IMU+GPS and 2 standard servos)
cheers
Jim
Looking at the ardupilot google code page, I noticed that the recommended battery clocks in at 11.1 volts. So how forgiving is the system? Will 12 volts fry this thing? Do all systems, including the engine and servos run on 11.1 volts as a common standard?
Looking at the mA measurements that you guys have given, it doesn't seem very unlikely that solar cells could be used to provide an adequate amount of power for all systems here:
http://scientificsonline.com/product.asp?pn=3026810&cm_mmc=Merc...
If there was some kind of a table that included parts and volt/amp requirements, as well as weight measurements, I can actually build the system first and then find the plane to carry it.
Thanks for the input guys.
Jim
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=...
this one and power your ardupilot off of battery power, you can find how in the ardupilot manual.
http://code.google.com/p/ardupilot/wiki/ArduPilot
