PPM channel mapping?
I have a 6 channel PPM receiver that I have connected to my pixhawk. I understand you can map channel 1 to 4 but I need to map channel 6 to 7.
I have no use for the options that come on channel 6 but channel 7 has auto tune and I need to trigger it.
Is there any way to map channels that are above channel 4?
  • Not a problem. You can map channels around but you can't change the channels that Ardupilot wants to use for autotune or flight modes. IF you wan to use channels 6 and 7 for other things yes you can map them around.
    Controlling external devices like Gimbals and lights with APM &...
  • This reply was deleted.
    • No the problem is I only have a 6 channel transimtter so I cant map channel 6 to 7 through transmitter .
      • There is an outstanding item for RCMAP to be extended....  Have a look at the bug list and it should tell you what's its status is.
        • Thanks chris. I remember reading something about it some time ago.
  • Anyone?
