Distributor
Problem connecting Pixhawk and Futaba receiver
Hi
Two of my customers have trouble setting up the Pixhawk - I myself have a Pixhawk, but don't use a Futaba receiver, thereby I can't replicate the problem (I would like to find out if the problem is connected to the receiver they use, or something else).
Both use a Futaba R7008SB receiver.
Both managed to upload the Firmware to their Pixhawks - but they are not able to do the radio calibration (the Pixhawk doesn't "see" the receivers, the bars in the calibration are all grey).
They have nothing else connected to the Pixhawk, except receiver (connected to the right port / RC), buzzer, safety switch and USB cable.
The Pixhawk signals via the big LED "pre-arm check failed" (which makes sense ;)
They power the Pixhawk via USB and at the same time with a LiPo (via the Power Module).
The receiver is "found" by the remote, the LEDs are on, the setting of receiver and remote (regarding the use of the SBUS) seems to be right. They use the right port of the receiver to connect to the Pixhawk.
I am happy about any suggestions ...
Thanks a lot in advance
Felix
        • Wish I knew. What I understood from the documentation is that if you go to the screen where you can set it up and flip switches on the transmitter then the correct row will highlight and you can choose
          Either my transmitter isn't sending anything though the channels or the Pixhawk isn't picking up anything or maybe it just doesn't work and the documentation is wrong
          Going to remove the Pixhawk from the equation tomorrow and see if the switches move a servo connected to the receiver. If this doesn't work at least I know the transmitter isn't set up to send anything yet and I need to figure out how to do that. Been reading the Futaba book, but couldn't get a picture to translate the names they give s1, j1 and so on to the switches and dials on the transmitter.
  • Hey guys, noob here with futaba 14sg and 6303sb on its way for a 3dr diy quad. Will the 6303 sb work with pixhawk? This thread is quite confusing. Wiki says 6303 works users is this thread says it does not. Can someone please clarify? Thank you.
  • SBus doesn't seem to be working at the moment.  I would say best option is just to buy the PPM Encoder and use that for now
    I went back to SBus, because I couldn't just leave the problem alone just to try things again after it was working with the PPM Encoder
    This is what I did
    Reverse throttle on the transmitter
    Plug a battery into the Pixhawk
    Flash 3.1.4 of any firmware
    Plug the GPS in correctly as shown in the picture.  Note, there are more pins on the Pixhawk than on the cable
    https://www.flickr.com/photos/92380311@N04/13993389039/
    Leave the Pixhawk outside for a couple of minutes until it can find the GPS
    Plug it back into your machine
    Connect using Mission Planner
    Can't see the transmitter
    • 3.2-rc1 support R7008SB.
      Download : MP beta firmware.
      • I will try that again tonight, but last time I couldn't get past the RC failsafe with the beta firmware.
        • Failsafe check mode changed in 3.2.
          Only activate when ARMED so you can test it without battery only usb.
  • Does anyone have a step by step guide on how to overcome this problem? After reading all the comments I am not sure what does and doesn't work.
    I have received my pixhawk today and have a T14SG radio and R7008SB receiver. I have set the receiver to mode B and plugged the servo cable into channel 8 on the receiver and RC in on the pixhawk. Is there anything I need to do on the Tx? It is currently set to FASSTest-14CH.
  • I decided to buy the PPM Encoder because of the issues I have been having.  I was able to even arm the Pixhawk using the PPM Encoder.  So I am able to use the current release.  I found a video online to show how to arm the Pixhawk (https://www.youtube.com/watch?v=8u9DUDT2Ovg)  I don't remember seeing anywhere that you need to pull the two control sticks down and together of the transmitter to arm, but it works so I am happy.  Now I just need to get the servo connected to the Pixhawk
    @Kobus: The servo is not supposed to move (this would be quite dangerous during calibration, imagine you have an electric motor connected). Its also unpowered - the power supply is for the avionics exclusively, you need to provide servo power from a different source. It would be unsafe (in general, there are setups where it would be fine) to solely rely on the servo power for the autopilot.
    You need to arm the autopilot probably first - in general, I recommend to spend some time with the documentation to familiarise yourself with the system.
    • Thank you.  Been reading so much the past couple of week and all the information is scrambled by now.  I will start from the beginning again and work through now that I know the Sbus is working.  Been learning Pixhawk, Futaba SBus, Futaba receivers and transmitters, ESC, BEC, UBEC and and and.  When I worked with RC many years ago the transmitters still needed crystals and ESC's didn't exist so I have been catching up on probably 20 years of RC in the past couple of weeks
      I was about 70% sure the servo wouldn't work, but since the message on the screen always said to make sure things are disconnected I thought maybe, just maybe.  Didn't hurt to test.  Al least I didn't burn out any ports like I normally do with Arduino's :)
      I see the flashing I have is that RC failsafe has been activated so I will look at that tomorrow.  Also going to try the current firmware again just to double check that it is working with SBus since I know the new firmware now works with SBus
      Hopefully these posts will also help other guys now to get their Futaba SBus up and running
DIY Drones via Twitter
Dec 12, 2021
DIY Robocars via Twitter
Dec 12, 2021
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Dec 4, 2021
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28, 2021
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26, 2021
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25, 2021
@gclue_akira CC @NVIDIAEmbedded
Nov 23, 2021
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23, 2021
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23, 2021
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20, 2021
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20, 2021
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9, 2021
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31, 2021
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29, 2021
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25, 2021
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23, 2021
