Distributor
Problem connecting Pixhawk and Futaba receiver
Hi
Two of my customers have trouble setting up the Pixhawk - I myself have a Pixhawk, but don't use a Futaba receiver, thereby I can't replicate the problem (I would like to find out if the problem is connected to the receiver they use, or something else).
Both use a Futaba R7008SB receiver.
Both managed to upload the Firmware to their Pixhawks - but they are not able to do the radio calibration (the Pixhawk doesn't "see" the receivers, the bars in the calibration are all grey).
They have nothing else connected to the Pixhawk, except receiver (connected to the right port / RC), buzzer, safety switch and USB cable.
The Pixhawk signals via the big LED "pre-arm check failed" (which makes sense ;)
They power the Pixhawk via USB and at the same time with a LiPo (via the Power Module).
The receiver is "found" by the remote, the LEDs are on, the setting of receiver and remote (regarding the use of the SBUS) seems to be right. They use the right port of the receiver to connect to the Pixhawk.
I am happy about any suggestions ...
Thanks a lot in advance
Felix
        Thanks for all the info guys, I had it running for a while ( throttle needed reversing but all else was good). Strangely after 5 or so minutes it all went wrong. The roll now also does throttle and yaw, the throttle only does channel six and everything else is inop- I swear I did nothing! I'm sure this is a personal issue, kobus is right- it's a lot of new tech to get on top of quickly. Happy days!
          Hmm, ran with qcontrol to check-same issues. Reflashed back with mission planner and it all works again. Think I will wait for stable version, just incase - the machine is too valuable......
  • Is this currently working for everybody?  I read all the comments before I bought my receiver and the Pixhawk and assumed since this was a couple months ago it should be in the current firmware by now
    I setup my R7008SB receiver to SBus (led flashes red twice)
    The transmitter (T14SG) has been setup in the link menu as FASSTest-14CH Single G
    I am able to link my receiver to my transmitter and connect a servo on the receiver and the servo moves when I move one of the sticks on the transmitter so I know the messages are coming through to the receiver
    I have the cable plugged into channel 8 on the receiver and on RC on the Pixhawk.  The receiver is powered from the Pixhawk so I know the connection is the correct way around.  The Pixhawk flashes yellow twice and then off so it has an issue
    I installed Mission planner and used the Wizard to setup the Pixhawk.  I installed Quad 3.1.3 on the Pixhawk.  When I get to the point where the Pixhawk should detect the messages from the receiver it doesn't show any messages on the screen
    I also tried using the manual setup and it doesn't see anything
    Here are some videos I recorded to give more information.  The videos of the Pixhawk are a bit dark, because the world is dark at the moment :)
    http://youtu.be/Dmk2AQAVQK0
    http://youtu.be/pxg_DLKRMWA
    http://youtu.be/0Aawev2i6RY
    http://youtu.be/Z-YAByRrKls (busy uploading as I am writing this)
      In this video here:
      You have not actually connected the receiver correctly with its S.Bus output port. You need to plug into a different slot on the receiver. That's the one port which is rotated 90 degrees from the other ports. The R7008SB definitely works.
      -Lorenz
      • I tried now also in the slot that I read was the SBus 2 slot.  Still nothing.  Not sure what I am missing, probably something small somewhere as these things always are.  Is there some way I can see if messages are actually arriving on the Pixhawk?
        I will try the D slot, so channels 9 to 14 tonight and see if that makes a difference.
        • Hi Kobus,
          Please wait for APM 3.2 release. The R7008SB will not work with T14SG, AC3.1.x and Pixhawk.
          My R300SB and T10J is just work fine with APM3.2 Dev.
          • Where can I download the 3.2 DEV version already built?  I tried to build the latest packages last night, but when I arrived at my PC this morning I had alot of errors saying it couldn't rename files and things like that.  Probably security issues on the machine
            • http://firmware.diydrones.com/Copter/latest/
              Select your mode type and download ArduCopter-v2.px4 file version.
              In mission planner select load custom firmware.
              (If you cant see this menu switch on advanced view in config/tuning-planner menu)
              • I believe I am closer.
                I flashed the latest firmware in Mission Planner then I went to QGroundControl to calibrate RC.  The female voice keeps on going on about RC not calibrated while I am trying to calibrate it.  I was able to move throttle, yaw and roll, but nothing else.  I could do it for maybe 30 seconds and then I lost connection and couldn't get connection back again.  None of the switches are detected.  Not sure if they are supposed to be detected.  The throttle and pitch don't reach min or max, they are always a bit higher than min and a bit lower than max
                • Cause, you are not connected to Pixhawk.
