I have a new Hex platform I just built and this is the first time I've used the PixHawk.
I'm using the DJI E600 ESCs and Motors.
When I arm and slightly increase throttle, not all the motors are starting at the same time.
When I increase the throttle, the ones that started last are running slower than the rest.
If I leave them running on low throttle, the slow ones eventually slow down and stop.
I've tried to calibrate the DJI E600 ESCs to the Pixhawk, but they won't calibrate.
This apparently is correct as the DJI E600 OPTO ESC do not require calibration and so they won't allow a calibration to run.  Love to hear you thoughts on this as well!!
I have flight tested everything today and its flying great once its in the air.
When Im going to take off I can see the platform tilt towards the slower motors until it lifts.
I've taken a video on my work bench with the props removed trying to show what I'm talking about.
You can view it here: https://www.youtube.com/watch?v=rkcmp7wbZTE
Any help / Advice on this issue?
Has anyone else run the DJI E600 system on a PixHawk?
  • I have been and are still having the same problem. I'm running dji e800 on pixhawk px4 with my motors stopping also.
    I am running apm planner on a Mac and I can't find the paramaters you suggested to change.
    MOT-SPIN-ARED. I only have standard params.
    Oh sorry also using taranis plus radio.
    For abound 4 months I've been trying to get it all working, each time getting closer and closer.
    So to get to the point of havering the motors just to spin got me excited like you wouldn't believe.
    I have no hair left!
    Please can someone help!!
  • Can anyone share their starting PID values for the E800 kit with an extended Tarot 680pro?
  • This reply was deleted.
  • It looks like we may have a solution.
    I'm doing some testing and will keep my results updated here:
    http://charlottefpv.com/topic/problems-with-dji-e600-esc-motors-not...
  • i plan to built a Tarot 680 Pro with DJI E800 kits but my concern is same as your since i plan to use Pixhawk FC and how do we calibrate for DJI motors
    Hope somebody can answer to our concerns
    Bill
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Thursday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
