Pusher VS Tractor, Raven vs Stalker
Ok, so I was researching the RQ-11 Raven, as I'm thinkinig about designing a plane based on it, but discovered a new one.  The Lockeed Martin "Stalker.  I really like both planes, but prefer for FPV work, the clean nose of the Raven.  As for building/designing, the Stalker would be hands-down easier.  What are your all's opiniions on this?  Is the tractor ok?  At least the fuse is tall enough to keep the prop of the ground in a belly landing.
Stalker:
http://www.designation-systems.net/dusrm/app4/stalker.html
Raven:
http://www.designation-systems.net/dusrm/app2/q-11.html
Thanks,
Tim
  • Both tractor and pusher work just fine provided you design for them
    a pusher is more efficent than a tractor due to not having the high speed air running over the fuse. But having the the prop infront of control surfaces alowes you to have a poor mans vectored thrust. For a uav not having the prop in front is nice incase a person ends up in the flight path.
  • Having used the Raven before, it works pretty well in flight, though actually landing it is really just crashing it into something (usually the ground, via a stall)
