So I almost have my quad up and working. My quad looks almost like like Jose's quad copter part ii. It's built on the ArduPilot Mega with OilPan. I'm trying to figure out what I need to do, in order to have the left and right spin CCW. I'm using the same props, motors, and ESC. Is this a software or hardware "problem"? I'm just scared to let go for the first time.
How is this in the case with, http://www.diydrones.com/profiles/blogs/arduimu-quadcopter-part-ii This project uses only standard props. This is the type of setup that I have give or take a few details. It's a few cm bigger and is based on the mega. I think I even have the same motor, ECS, and props. Does the 8 degree angle over set this need? and should I have two CCW and two CW?
