What is that RCTimer ArduFlyer V2.5 Kit Flight Controller compared to 3D robotics? it seems to be the same but much lower price, it should be a stupid question, but why do they have such low price?
"And if you read the post Chris wrote, there are no factual errors"
what about this "which can destroy the board if used incorrectly (wrong fuses set). "
a wrong fuse setting can happen no matter which board you have, no matter how it is programmed,
Fact is, you really cannot DESTROY the board with a wrong fuse setting, you can temporarily stop it from working but NOT destroy it, and it applies equally to APM and ArduFlyer
Answering we don't support xyz to even the simplest attempt at discussion sends a really bad message.
Well done u4eake - it was about time someone 'clarified' the situation.
I have been a long term supporter of DIYdrones - and no doubt will continue to be - but I'm also a discerning buyer and don't care for deliberate obfuscation.
Hi Chris and Joe,
Sorry... I am being a noob here.. Just trying to understand your statement... "So you won't be able to upgrade the firmware on that chip without using an ICSP programmer"
Does that mean that I cannot load Arducopter 2.9 when it will be available ??? Or are we talking about some other firmware ??? I am currently running 2.8.1 and it works great... However, I have another two sets of APM 2.5 bought from DIY.
Another point... the boards that came from DIY were deep purple in color and did not come with any code loaded. The red blue and green lights were running in sequence upon connecting to the USB.
Whereas, the board from rctimer are not that deep purple in color and also came with 2.8.1 loaded... dont know why ??? Is that something that we are talking about here??? and should that really bother me as an end user ???
Thanks for your time.
Hi Chris,
Can you help me, I searched and could not find instructions for APM 2.5 programming of 32u2 nor the hex file to program it from.
Where do I find the latest hex file to program into the APM 2.5 32u2 ?
What are the correct fuse settings for APM 2.5 32u2 ?
I have all the Atmel programmers up to AVR ONE so I would be using ISP programming using Atmel Studio 6.0.
Thanks.
I also do have an Arduflyer 2.5 which is working fine, here are the fuse settings read from the 32u2 and 2560, I have attached the 32u2 flash and EEPROM Iintel hex files read from that Arduflyer 2.5 32u2
Detected device
Device name ATmega32U2
Device signature 0x1E958A
Datasheet information
ATmega32U2
CPU 8-bit AVR
Flash size 32 Kbytes
EEPROM size 1 Kbytes
SRAM size 1 Kbytes
VCC range 2.7 - 5.5 V
Maximum speed N/A
VCC = 5.2V
BODLEVEL = 3V0
HWBE = [X]
DWEN = [ ]
RSTDISBL = [ ]
SPIEN = [X]
WDTON = [ ]
EESAVE = [ ]
BOOTSZ = 2048W_3800
BOOTRST = [ ]
CKDIV8 = [ ]
CKOUT = [ ]
SUT_CKSEL = EXTXOSC_8MHZ_XX_16KCK_65MS
EXTENDED = 0xF4 (valid)
HIGH = 0xD9 (valid)
LOW = 0xFF (valid)
LB = NO_LOCK
BLB0 = NO_LOCK
BLB1 = NO_LOCK
LOCKBIT = 0xFF (valid)
Detected device
Device name ATmega2560
Device signature 0x1E9801
ATmega2560
CPU 8-bit AVR
Flash size 256 Kbytes
EEPROM size 4 Kbytes
SRAM size 63 Kbytes
VCC range 1.8 - 5.5 V
Maximum speed N/A
VCC = 5.2V
BODLEVEL = 2V7
OCDEN = [ ]
JTAGEN = [ ]
SPIEN = [X]
WDTON = [ ]
EESAVE = [ ]
BOOTSZ = 4096W_1F000
BOOTRST = [X]
CKDIV8 = [ ]
CKOUT = [ ]
EXTENDED = 0xFD (valid)
HIGH = 0xD8 (valid)
LOW = 0xFF (valid)
LB = NO_LOCK
BLB0 = NO_LOCK
BLB1 = LPM_SPM_DISABLE
LOCKBIT = 0xCF (valid)
ArduFlyer 32u2 flash.hex
ArduFlyer 32u2 Eeprom.hex
Just a warning for those considering the RCTimer APM 2.5 clone: for some reason they messed up the 32u2 firmware, and it doesn't come with the DFU bootloader (it just has some unknown version of ArduPPM flashed directly). So you won't be able to upgrade the firmware on that chip without using an ICSP programmer, which can destroy the board if used incorrectly (wrong fuses set).
I have two of these boards... One works ok... the other does not work right... Every sec or two the copter would
twitch... or jump... I changed back to APM2.0 and its gone... flies great now..... Also the other clone 2.5 will not work properly when I plug in my maxstream telemetry... I don't know if its something with the 2.5 or what because it works great on the 2.0...
Eddie
I've got my arduflyer up and running for a while now. It's running arduplane on a mscomposite swift II.
It has already done several missions, the longest of which a 9km mission with autolanding. That one took 850mAh out of my 1000mAh battery, so it's about as far as can safely be flown with my config.
I followed the drone in my car with the telemetry module taped on the roof and laptop on the passengerseat with speech enabled. Though I didn't see the drone until 500m from it's destination, I could follow it on the laptop the whole time while driving.
Anyway, the arduflyer works just fine.
I did have to reconfigure the gps though and rewire the cable.
I have it working with APC220 telemetry modules, but a 3DR radio from rctimer is also on the way.
Here you can find extensive guide about this clone. I powered it up yesterday - basic staff including GPS and radios work.
http://www.multi-rotor.co.uk/index.php/topic,676.0.html
Ardupilot from 3DR and Arduflyer are the SAME. I have both of them. No Difference at all...
Infact the 3DR ardupilot is manufactured in the same factory in China. It is DESIGNED in California but productionized in CHINA from the same factory.... LOL
RCTimer's Arduflyer is the same as Ardupilot 2.5 with just the printing as Arduflyer... Rest EVERYTHING is the same. EVEN the quality of the connectors, wires etc is the same. I happen to peel off the RCTIMER logo plate from the bottom of the 433 Data radio, and it read 3DRobotics on the below... LOL
Just got full package from them.
I haven't try it yet but boards manufacturing quality is surprisingly AmaZIng!.I'll keep you posted.
