Reading voltages for lipol 3Cell battery
Hello everyone,
I have an ardupilot mega that I'm powering with a 3cell 2500mah battery, through an ESC. the ESC is outputting exactly 5v. I've followed the instructions in the manual to setup the voltage sensor. I soldered 3 of the 3.9k resisters in their place, leaving the 4th one open. I've also got the balancer cable soldered and plugged in.
The problem seems to be an accurate reading, I do indeed get a reading but it's nowhere near accurate.
This is what I've added to my APM_Config.h, straight from the manual.
//Battery:
#define BATTERY_EVENT 1                 // (boolean) 0 = don't read battery, 1 = read battery voltage (only if you have it wired up!)
#define BATTERY_TYPE 0                  // (boolean) 0 = 3c (11.1v), 1 = 4c (14.8v)
#define INPUT_VOLTAGE 5.2               // (Volts) voltage your power regulator is feeding your ArduPilot to have an accurate pressure and battery level readings. (you need a multimeter to measure and set this of course)
#define VOLT_DIV_RATIO 3.0              //  Voltage divider ratio set with thru-hole resistor (see manual)
#define LOW_VOLTAGE     11.5            // Pack voltage at which to trigger alarm
I believe the problem lies in the VOLT_DIV_RATIO. In the "Correct Example" for a 3S battery, it lists the volt_div_ratio as 3.0, however
When set to 3.0, the APM outputs about 10.2volts on a fully charged battery, however if I run a miltimeter over the last pin of the cell balancer plug it reads about 12v.
There in another part of the manual that lists the correct div ratio as 2.56, if I set this in the config then the APM outputs about 8.2v as being my voltage, even worse.
Can someone shed some light on what I am/have done wrong? Cheers
  • Hello Jon,
    The other guys were right. You need to tweek the settings to calibrate for imperfect resistors. One obviose thing I see is your< #define INPUT_VOLTAGE 5.2>. You say your esc puts out exactly 5.0 V, then this is the value you must set. Your readings  are 10 % low with this value. Set it value to 5.0 and the VOLT_DIV_RATIO back to 3.0 and start from there.You need to take the time to read the comments (every thing after the //) in the APM_Config.h file. They explain the function of each line. Every detail is not in the manual.
    Nothing is wrong, just increase the ratio value until the measured voltage matches the actual voltage. In your case around. 3.2ish? All resistors have "tolerance" which can be upto 5%, so values need tweaking.
