Recommended PIDs for a large Quadcopter?
Hi all,
Ive just finished building a 1100mm 15 pound quadcopter with:
-24 inch props
-6215 kv170hv motors with 80A esc
-Pixhawk
-12s set up with 4x8A 6s batteries
Today I did the maiden flight and it lasted 15 seconds before it flipped and crashed.
I took off in loiter mode with 3D fix and the quad was shaking and wobling a lot before it flipped.
At first I thought Ive got 2 motors mixed up but I didnt, everything is set up correctly and props are spinning the right way.
Could wrong PIDs cause this woble and flip?
Im using the PIDs from a much smaller 750mm 15inch prop quad.
Please, I would appreciate it very much if someone could recommend the best PIDs for this rig.
Thanks,
David
  • Great, I highly recommend that you try autotune, configured correctly, it does a better job than most users can do, if nothing else, will put you on the right track to a good tune.
  • Hey Andre!
    So I flew again today and it flew beautifully!!
    I used the PIDs you suggested and also put the stabiliza pitch and roll on channel 6 in one of the dials in my Futaba with a 2 to 7 range...
    trid 4 first and it wobbled, then 2 and it went nuts and then I cranked the dial to the max 7 and it was amazingly stable.
    I will do a fine tunning this week and then try a to see how long it will fly for.
    Anyway thanks for your help!
    David
  • https://youtu.be/cVIA1TQvark
    Andre, thanks so much for your reply.
    Please have a look at the video I uploaded in youtube from the crash.
    I took off in loiter mode, I tried switching to stabilize but was too late.
    Initially I thought Ive got a motor wrong or a plug up side down but everything was right which led me to think PIDs are the culprit.
    I will try again starting from your suggested numbers and let you know how it goes.
    Thanks again.
  • you can't just copy PID's from one thing to another, as I hope you learned.
    nor can anybody here give you correct PID's except if they have exacty that setup, with same wight/balance/end ESC's.
    Assuming you calibrated ESC's , you should have lifted it up a bit in stabilize, barely off ground, and if wobbly, reduced pids.
    wild guess may be:
    rate pitch/roll P,I = 0.08
    rate pitch/roll D 0.004
