RFD900, RFD900+ - New long range radio modem
Hi All,
I would like to introduce you to a new radio modem that we developed for very long range datalinks!
http://rfdesign.com.au/RFD900.php
Some of the key features of the RFD900 are as follows:
  • Multi point and point to point link capability.
  • Long range >40km depending on antennas and GCS setup.
  • 2 x RP-SMA RF connectors, diversity switched.
  • 1 Watt (+30dBm) transmit power.
  • Transmit low pass filter.
  • > 20dB Low noise amplifier.
  • RX SAW filter.
  • Passive front end band pass filter.
  • Open source firmware / tools, field upgradeable, easy to configure.
  • Small (30 x 57 x 13 mm), light weight (14.5g).
  • Compatible with 3DR / Hope-RF radio modules.
  • License free use in Australia, Canada, USA, NZ.
These modems are designed to support long range applications, while being easy to use and affordable.
These modems have been flying in various platforms and have demonstrated excellent performance in real applications.
RFD900 modems are now available at: http://store.rfdesign.com.au
Support within APM planner and the radio configurator from Michael Oborne is already available.
It works seamlessly with APM planner, all radio Mavlink parameters are available.
Update, December 2014:  The RFD900+ with improved specifications is available now at:
http://store.rfdesign.com.au/rfd-900p-modem/
Seppo Saario
rfdesign.com.au
  • We decided to be cruel and do some extreme testing to see how the RFD900 modems behave under extreme cold conditions.
    The modem was shut down and allowed to cold soak at -60 degrees C. Then powered up to maximum power and had a look at data transfer and connectivity tests. All works just fine.
    The modems are available from Australia from the RFDesign web-store, but we are also making arrangements for a wider distribution network. -- Announcements coming soon!
    3692475291?profile=original
    https://storage.ning.com/topology/rest/1.0/file/get/3692475291?profile=original
  • What kind of range can be achieved?
    We did some preliminary tests with the radios at full power, 1 Watt to see what is possible.
    This was of course done in the middle of the night in the freezing cold (Winter in Brisbane, Australia).
    One radio was on Mt Cootha, just to the northwest of the city, and the other radio was out of a car window on a wooden stick, connected to a laptop. (at ground level).  This is quite nasty for multipath and noise at ground level.
    We achieved a bit over 25km with this configuration, at standard air data rate settings (64k).
    The picture below shows the two locations where we had a stable link.
    3692458482?profile=original
    The range can be significantly improved with getting the antennas raised above ground level and reducing air data rate which will reduce noise in the receive channel due to narrower filters.
    The antennas used were the standard 1/2 wave dipoles at each end of the link.
    Next tests will be to an airborne platform, with the GCS antenna elevated a couple of meters.
  • RFD900 Modems are now available for purchase from the RFDesign online store : http://store.rfdesign.com.au
    End of last week we ran through SMT production in Melbourne, Australia and this week we have run through testing and finishing of the radios.
    So far they have flown with a few open source autopilots, with nice range :)
    RFDesign
    RFDesign designs and manufactures the Antennas, RF Electronics and the RFD900 radio modem
  • Seppo,
    I thought I would check in and see how your testing is going?  Are you getting close to production units yet :-)
  • Hi all,
    i have 2 DNT900 module for sale.Contact me if you are interested.
    Thanks.
  • Hi Seppo,
    Do you intend to manufacture RFDxxx for Europe....868MHz...433MHz..etc.?
    Best regards
    Nick
  • Hi Greg,
    The radio is a clean-sheet design.  It is based on a Si1002 transceiver from SiLabs which allows a software solution called "SiK" to be used on it.
    SiK is also used on the 3DR radios, so protocol, framing, hopping etc. is identical which allows them to talk to each other (900MHz versions only).
    One thing that I needed was long range and diversity.  Diversity being especially useful as it automatically chooses the best antenna for each packet it sends/receives.  For UAV or mobile applications, having two antennas, one in each polarisation, reduces the chance of link loss significantly.  I have not seen any ISM band radios to date that support diversity by default.
  • Seppo very nice product. I just started using the 3DR Hope-RF based Radios (915 MHz)and was looking to purchase an amplifier from Shireen to increase the range and here is the perfect soultion for me and in one module. When you say 100% compatible, is your RFD900 using the Hope RF module or some thing else?
