RFD900, RFD900+ - New long range radio modem
Hi All,
I would like to introduce you to a new radio modem that we developed for very long range datalinks!
http://rfdesign.com.au/RFD900.php
Some of the key features of the RFD900 are as follows:
  • Multi point and point to point link capability.
  • Long range >40km depending on antennas and GCS setup.
  • 2 x RP-SMA RF connectors, diversity switched.
  • 1 Watt (+30dBm) transmit power.
  • Transmit low pass filter.
  • > 20dB Low noise amplifier.
  • RX SAW filter.
  • Passive front end band pass filter.
  • Open source firmware / tools, field upgradeable, easy to configure.
  • Small (30 x 57 x 13 mm), light weight (14.5g).
  • Compatible with 3DR / Hope-RF radio modules.
  • License free use in Australia, Canada, USA, NZ.
These modems are designed to support long range applications, while being easy to use and affordable.
These modems have been flying in various platforms and have demonstrated excellent performance in real applications.
RFD900 modems are now available at: http://store.rfdesign.com.au
Support within APM planner and the radio configurator from Michael Oborne is already available.
It works seamlessly with APM planner, all radio Mavlink parameters are available.
Update, December 2014:  The RFD900+ with improved specifications is available now at:
http://store.rfdesign.com.au/rfd-900p-modem/
Seppo Saario
rfdesign.com.au
    Hi everyone,
    We are trying to put RFD900+ in a single channel (non-hopping) mode to execute some frequency tests, does anybody have a hint to put the module in "Test-Mode"?
  • Thanks for that Paul. Hopefully will get it sorted shortly and be in the air soon.
    Glen
  • you need a jumper if you are powering the radio from FTDI or from pixhawk
    pin 4 is the + (positive power) pin for the radio, 1 and 2 are the - (negative) ground pin and are interconnected, pin 5 is + from the cable and pin 5 and 6 are interconnected, so you need to jump 6 and 4 to get power from pin 5 to pin 4.
    if you use external power supply  4 is + and 1 or 2 is -
  • This is off the RFD900 datasheet/manual.
    Pin 1 of the FTDI cable (black wire) should connect
    to pin 1 of the RFD900 header. In order to
    power the modem from the +5V USB power, a jumper is
    needed to connect pins 4 and 6.
    To power the modem from an external +5V supply, con
    nect the power to pins 2 and 4 as
    shown in figure 5.1.
    Thought this was how to set up.
    no, you are reading "it" wrong.   what are you reading?
    Glen Leeon said :
    Am I reading this right?
    The modem that is on the quad should have a jumper across pins 2 and 4.
    And the modem connected to computer via USB has jumper across pins 4 and 6?
    Thanks.
    Glen
  • Am I reading this right?
    Thanks.
    Glen
  • V2.4 firmware for rfd900x radio.
    Here is a link to AT command interface.
    http://rfdesign.com.au/documentation/sik-at-commands/
    The new one will vary slightly. ATI5 will show new parameter set, and ATI5? will give parameter info.
    Kent
    SiK AT Commands
  • I assumed your talking 2.4 firmware, instead radio version number ?
    kent Martin said:
    Glen,
    Please first ensure you have version 2.4 or later. There was a bug with ppm record on earlier versions.
    If yours isn't let me know, and I can send you the correct version.
    PPM input or outputs pins can be configured for your ground and air radios respectively.
    Set up PPM input and output before recording fail safe ppm signal.
    The air side radio should also record your desired PPM signal in the even of radio link loss.
    ( You can do this with remote AT if you like, note it will give an error if you try and record the ground side).
    You should set your controls to whatever will let you flight controller know that something is wrong,
    Then type in the AT command to record the ppm stream. Check in Mission planner that the signal is correct, then record it.
    Put your controls back to normal and check mission planner has returned to normal, then turn off your transmitter and ground and check that mission planner is going into the correct mode for a fault.
    AT commands are:
    1. for PPM input (ground)(pin 15 of header GPIO1.1,GPI1_1R/CIN ) "ATI16 = 1 "
    2. for PPM output (pin 15 of header GPIO1.1,GPI1_1R/COUT ) "ATI17 = 1 "
    3. to record the PPM stream for link loss "AT&R"
    The PPM input will need to be level shifted down to 3.3V as it is not 6V tolerant, which is likely the level coming out of your transmitter.
    You can make one up with 3V zener and 1K resistor, or we will hopefully be selling adapters for this soon if you are not familiar with this yourself.
    Note you can't configure both PPM input and output on one device as they are the same pin and you will have to disable one before enabling the other.
    Note also that you configure the correct end and don't mix them up.
    Once configured you should be able to control your aircraft using the radio and use mavlink at the same time.
    Note, you might notice it's not quite as responsive due to delays, but it is very flyable.
    If you're drone racing, it might not be what you're after. (maybe in the next version of firmware this might get improved on).
    Thanks,
    Kent
    Dennis and Paul,
    The multipoint firmware for RFD900 does not do relaying. It only supports a topology where you have multiple ground stations and one aircraft, so that you do not need to send packets between the two radios that are not in line of sight.
    I have built a firmware for the upcoming RFD900x that does do relaying and I will release the firmware once the RFD900x is released. We are using the firmware for OBC'2016 to get packets from the retrieval aircraft to the GCS via a relay aircraft. The firmware I've written is a fairly simple change to the point-to-point firmware rather than being based on the multipoint firmware. It only supports 3 nodes at the moment, but could be extended to more nodes if needed.
    Cheers, Tridge
  • Kent,
    Thanks for the info. Loads of it there for me to digest at this stage but will work slowly through it get to where I want to.
    Firstly. I am not familiar with AT commands and where/how I view/change and program them. Can you point me the right direction? What do I need to use to set up and even check which version my modems are at the moment?
    Glen
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
yesterday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
