Hi All,
I would like to introduce you to a new radio modem that we developed for very long range datalinks!
http://rfdesign.com.au/RFD900.php
Some of the key features of the RFD900 are as follows:
- Multi point and point to point link capability.
- Long range >40km depending on antennas and GCS setup.
- 2 x RP-SMA RF connectors, diversity switched.
- 1 Watt (+30dBm) transmit power.
- Transmit low pass filter.
- > 20dB Low noise amplifier.
- RX SAW filter.
- Passive front end band pass filter.
- Open source firmware / tools, field upgradeable, easy to configure.
- Small (30 x 57 x 13 mm), light weight (14.5g).
- Compatible with 3DR / Hope-RF radio modules.
- License free use in Australia, Canada, USA, NZ.
These modems are designed to support long range applications, while being easy to use and affordable.
These modems have been flying in various platforms and have demonstrated excellent performance in real applications.
RFD900 modems are now available at: http://store.rfdesign.com.au
Support within APM planner and the radio configurator from Michael Oborne is already available.
It works seamlessly with APM planner, all radio Mavlink parameters are available.
Update, December 2014: The RFD900+ with improved specifications is available now at:
http://store.rfdesign.com.au/rfd-900p-modem/
Seppo Saario
rfdesign.com.au
The rfd900x programmer and binary files are up on the web page now.
RFD900x Flash Programmer V1.0.0.13.zip
http://files.rfdesign.com.au/tools/
RFDSiK V2.53 rfd900x.bin at
http://files.rfdesign.com.au/firmware/
I think it is already stuck in boot mode, i'm not able to communicate through AT commands, it always answers with "???" however i could connect to the other one and find out that the firmware is "Sik 2.53"
The other radio responds as usual, when i connect it it starts blinking green, but the first one still on boot mode.
Is there any way i can upload firmware? just point me to the solution and ill figure it out.
Thank you very much.
Rodrigo
kent Martin said:
1.1 is the bootloader version.
What is the firmware version you are running?
Use AT commands.
Mission planner should tell you, if you don't know how to use AT commands.
There was an issue with rfd900x programmer Version 1.0.0.7 which is on the web page at the time of writing.
Don't use this to upgrade, or it will get stuck in boot mode.
A new version will be posted soon.
Does anyone have a link to firmware version 2.4 (mentioned by Ken earlier)? I've found links to version 2.4 for RFD900+ and RFD900u, but the RFD900x section is grayed out/no links.
Firware Download Page
Kent, thank you for your repply.
This is what i get when connecting to the RFD XMODEM programmer, the firmwares i downloaded from github and the modem itself when plugged it in.
Rodrigo
Rodrigo,
1.1 Firmware I assume is on a rfd900+?
PPM is not supported on RFD900+ only on RFD900x.
Can you confirm your hardware?
Kent
Hello Kent, I just got a coupple of radios and have the 1.1 firmware and cannot find the latest... could you help me with this?
kent Martin said:
Pin 15 is what is assigned to PPM in/out.
So, you can either connect a cable from your transmitter accessory port to the RFD, or you can connect a receiver to the RFD. If you connect a receiver to the RFD, you basically use the transmitter as normal, connect the receiver PPM output to the RFD900x pin15.
In either case, you need to be sure the signal is not more than 3.3v, so you may need to build a 'level shifter' to drop the ~5v signal from your transmitter or receiver to 3v.
Then on the aircraft side, you take the signal out of pin15, and in to the PPM/RC input of your flight controller.
There is some configuration.. Most of the info is in this post from Mr Martin:
http://diydrones.com/xn/detail/705844:Comment:2294249
Thomas Stanley-Jones said:
Can some one please tell me the best way to mount the RFD modems. I can mount it with double sided foam tape or I can mechanically fasten it with screw mounts and spacers.
If I hard mount it will it be affected by vibration?
Thanks in advance
Richard
yes there is have look here
https://www.rcgroups.com/forums/showthread.php?2037442-Ultimate-LRS...(using-2-OrangeRX-1W-TX)&perpage=100
