Roll works, pitch doesn't
In the pre flight instructions.
http://code.google.com/p/arducopter/wiki/AC2_Preflight
It says.
  • Roll the ArduCopter to the right. The right motor command should increase. The left motor command should decrease.
  • Pitch the ArduCopter down (the front motor should be lower in position than the rear motor). The front motor command should increase. The rear motor command should decrease.
When I have the APM planner up, and showing Action/AC2 Sensor/Motors.
If I roll the frame I can see the motors change speed accordingly to correct the roll.
But, when I pitch the frame, the front and rear motors (3&4) don't move one bit.
Also, when the frame is level, motor 2 runs higher than the others.
When I monitor the sensors, using Action/AC2 Sensor/sensors they all appear to be working correctly.  I can clearly see the pitch changing.
Any clues on what to look at?
  • Well tuning the motor controllers didn't do anything for me.
    I did it manually.  At least I know its done right.
    I reloaded the code and went through the setup process again.
    Its working fine now.
    Stabilize roll and pitch Pid P values were 0.54 before and after the code reload.
    Thanks for all your helps.
    Look at your PID values. I'll bet they are corrupted. probably the Pitch P value us 0.
