0 SCP1000 - how noisy is it suppose to be? Posted by endrew on June 6, 2010 at 3:01pm I am using the code Jordi released here, and i'm getting about 2 meter peak to peak readings when the sensor is absolutely steel. I expected much better results, the manual says 9 cm resolution. what good is it if the noise is 20 times as much? hight.JPG You need to be a member of diydrones to add comments! Join diydrones Email me when people reply – Follow
