Hi all,
  A couple of weeks ago I got bit by the bug to build a quadcopter from scratch.  I am purchasing the motors, ESC, battery, propellors, ect..., but I am designing and building the frame from raw materials.  I am programming the control system from a blank slate.  One of the things that will make this quad different than many others is that I will be attempting to track it's position in relation to it's start point purely from the accelerometer and gyro.  If that feature is successful, I plan to add the ability for it to fly autonomously by following pre-programmed way-points.  If the inertial position tracking doesn't work out, I'll just reprogram is to use standard Quadcopter controls and have fun with it.
  Here's a link to my Blog where I am writing about the process:
 http://philstech.blogspot.com/2012/03/quadcopter-project-overview.html
  Let me know what you think.
~Phillip
  • My latest blog post discusses the final parts of the physical build for my Quadcopter.
    http://philstech.blogspot.com/2012/06/quadcopter-build-status.html
    ~Phillip
    Quadcopter Build Status
    A blog about technology focusing on multicopters, my quaternion based IMU, and any thing else that catches my interest.
  • My latest quadcopter post is up.
      It discusses why inertial position tracking is not feasible with my current hardware.  This article will come as no surprise to some of you.  I have ideas I still want to try, but for now I will program my quad to use standard controls and have fun with it.
      I have no regrets with about trying.  It has been a fantastic learning experience.
    http://philstech.blogspot.com/2012/06/quadcopter-inertial-position-...
    Quadcopter: Inertial Position Tracking - RIP
  • Latest post discussed accelerometer filtering.
    http://philstech.blogspot.com/2012/04/quadcopter-accelerometer-data...
    Quadcopter: Accelerometer Data Filtering
  • What's the power rating, Kv, and operating voltage for your motors?
  • Hi Phillip,
    Good luck with your project, I always like to see other scratch-builders! I am sure if you stick with it you can get to something that flies nicely.
    Regarding inertial navigation/dead reckoning:
    I think your goals are ambitious, but will be very difficult to reach. I have tried something similar on a 32bit MCU and haven't gotten terribly promising results. One of the big problems is the accuracy of the attitude estimate. Even if the pitch or roll angle is off by only 0.1 degrees (which would be a spectacularly good result for hobbyist-class IMUs) you would accumulate a location error of 1/2 mile in 5mi - with everything else working perfectly...
    I think you will find that you really need other sensors to aid in the localization problem.
    Marko
  • The latest post details assembling the frame:
    http://philstech.blogspot.com/2012/04/quadcopter-frame-assembly.html
    ~Phillip
    Quadcopter: Frame Assembly
  • Latest post talks about my progress with the Inertial Position tracking:
    http://philstech.blogspot.com/2012/0...acking_29.html
    Quadcopter: Inertial Position Tracking Tech Update #1
  • Latest update just went up.
    Quadrotor Post #6: http://philstech.blogspot.com/2012/0...and-motor.html
    Quadcopter: Parts Arrive and Motor Mounts
  • I looked at your blog, and was curious as to what you do during idle time, where the core's not scheduled to process anything and is just waiting for the next scheduled time?
    Also, you have to be careful about frames of reference. Remember that your IMU is giving you data relative to the orientation of the craft.
  • Due to noise levels in the accel signals and reletively low resoloution, I don't think this is possible with the sensors. You will have to double integrate the accelerations to get distance data and errors wittl add up very quick.
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Thursday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
