Hello,
i am using mavproxy to communicate the drone with my laptop. I am trying to control it from the laptop and works well but it is a experimental stage, so, when i send a message using mavproxy to the drone i lose the control from the radio controller. This is very dangerous because if there is a problem flying i couldn't control the drone with the RC. I wonder why when i override the channels, i can't use the radio controller until i connect with the Mission Planner again.
Thank you.
    Hi Antonio,
    May I see your rc_override function? Are you sending an rc raw value of 0 to each channel after sending the override pwm to release control back to the tx?
