Servo End Point adjustment
I'm trying to limit the throw of the servo so it won't BIND. I can adjust it at my radio, but not to sure that's were it needs to be done at. I've been reading the Parameter setting...say RC3_ Parameters. there are "RC min PWM", RC trim PWM", and "RC max PWM". Is this were I need to do the adjustments. If so which PWM or which ones.Don't understand the  parameter definitions... http://plane.ardupilot.com/wiki/arduplane-parameters/ Any help will be appreciated.
Brian
  • Will this work for new elevon mixing?
    Yes, those are the settings to use: "RC min PWM" and "RC max PWM". RC trim PWM" is the center point if you need to change it, however...
    ...you must use the "calibrate radio" setup for normal functions like roll, pitch, thr and yaw, do not change them or set them in the Full Parameter list. Adjust them on your radio and then do the Calibrate Radio setup.
    Functions like gimbal or retract servo's can be setup in the Full Parameter list.
