Posted by Paul Williams on November 23, 2011 at 11:23am
Hi all.Im having problem setting up 50, the quad is very twitchy.Am I right in thinking first setup the acro mode, up the p value till it starts to wobble then back off till it stable, then change to stabilaze mode and setup the p value there.Acro mode is ok got the p rate set, but as soon as I enable stabilaze mode it is un flyable even if I set the p value to 0 it wobbles like mad.It was working fine on version 49 but I can't find a way to go back?Any ideas?
Though it may be mechanical problem the most likely is bad Rate values. One thing I did once was misplace the decimal point. You may need to lower Rate value for Pitch/ Roll first. Start low to see if it helps, ~.10
Thanks guys, i'll give it a try later and let you know how i get on.
