Share your drone info thread
Hi everyone,
I'm creating this thread to share your drone/copter information. I believe, this would help immensely for newbies like me during the initial build. For example, the Chris's blog on cheap Hobby King quad configuration is really a good resource.
I don't want to burden anyone who is willing to share their info. Hence all fields are optional. Atleast the first 5 fields are ideal. Please find the list of fields to copy/paste at the end, so you can start filling :-).
Here goes information about my quad.
frame: Quadcopter (3DRobotics)
controller/autopilot: APM1
esc: 20A (3DRobotics)
motors: 850Kv (3DRobotics)
propellers: 10x47, APC (3DRobotics)
motor to motor distance: -- inches
battery:  4S 3300mAh (Turnigy nano-tech)
total weight: -- lbs
flying time: 15 minutes (average)
radio: Turnigy 9X
video/osd: none
other: Sonar, Xbee, GPS/Mag, Attopilot current sensor
Misc:
Turnigy 9X: Mode1 -> Mode2 change, Li-ion battery hack
photos:
3690911422?profile=original
3690911286?profile=original
3690911495?profile=original
frame:
esc:
motors:
propellers:
battery:
flying time:
radio:
video/osd:
other:
Misc (hacks/mods):
photos:
  • very nice octo! what is your maximum payload? (at around 50% throttle I mean)
  • This reply was deleted.
      • yup_they_are_like_pringles_by_synersignart-d8mem9v.jpgneed I say more
        Flame wheel 450
        AR drone
        and two scratch builds
      • cool , what it needs now is wooden Props just to continue the theme. too bad we cant use compress air motor due to power efficiency. but it would be cool.
  • Just Ordered My Hardware For My New Mini FPV:
    -Hobbyking™ S250 FPV Racer Composite Kit 210mm
    -AfroFlight Naze32 Acro AbuseMark
    -HobbyKing Tiny OSD III (w/10Hz GPS and 80A Current sensor)
    -Multistar Elite 2204-2300KV Set Of 4 CW/CCW (2/CCW 2/CW)
    -TURNIGY Plush 18amp Speed Controller
    -5030 3 Blade Carbon Fiber Propellers
    -FatShark Teleporter V3 RTF FPV Headset System w/Camera and 5.8G TX
    -Turnigy TGY-i6 AFHDS Transmitter and 6CH Receiver (Mode 2)
    -Multistar High Capacity 3S 5200mAh Multi-Rotor Lipo Pack
    -Plus a bunch of wire, connectors, screws, Nylon Spacers/Nuts/Bolts, Straps
    Weight should be just under 730g (So a little heavy for a mini) - Looking for 15+ minutes hover
    I hope it flies, any expert opinion/suggestions/concerns are welcome.
    • 3702585170?profile=originalKids, Math Matters... So I got my parts in and got her assembled. Jumps off of the ground at about 40% throttle, and very gently flew for a little over 30 minutes before I got worried the low battery alarm wasn't working. Tested it and the 5200mAh S3 battery still read 10.8 v (Wow 15min would have done). Considered going back to flying but the stress of a fresh $1000 CND ( about $650 US right now) floating around was getting to me. I spent a weak of working out pitch/size/thrust/efficiency/weight putting this together. Sent the Teleporter back before I even opened it, QVGA is too low (Have OSD), Predator V2 are coming in the mail. Took Scott Messe's advice and order some smaller batteries as this thing is a mini tank, Excited to go exploring in FPV shortly.
      • So realizing that this hobby was going to be taxing my paychecks anyways, I purchased a 3D printer to save in the long run. 2 More drones using the same hardware as above, but with a battery tray designed to use either a 2200mAh Li-Po or a 5200mAh Li-Po, depending on if I want long flight or fast flight.
        3702720441?profile=original
        • Hi Matthew,
          Personal interest, which 3d printer did you buy and what is your experience in using it?
          What products have you printed sofar?
          I am interested in buy a 3D printer myself,
          so when I see comments e 3D printers, I try to find
          out more info from the 'man in the street'.
          Thanks for sharing!
          Regards
          gG
          • I'm Using a Print-Rite, $300 USD from hobbyking.com 210x210 non headed print bed. I do my modelling in Blender, (1 BU (Blender Unit) = 1mm). I slice using an upgraded version of the supplied Repieter-Host software. It's been fantastic once you figure out settings. Best print results are at 4mm for the first layer, then 2mm for the rest, but supports 1-4mm layers. Parts are strong.
            3702851146?profile=original3702851291?profile=original3702851364?profile=original3702851421?profile=original
        • 3702799215?profile=original3702799070?profile=original3702799185?profile=original
      • R.I.P. Mini Drone. At about 600 meters she started to oscillate then went into an uncontrollable free fall. I think one of the carbon fiber props either came apart or became unbalanced. Damage: Video transmitter, FPV camera lens, 3 props, screen on Emerson action cam, both wings, and battery. Worst part, Camera lost its recording... :-(  Next build, Hex or Octo-X with motor failsafe.
        3702713548?profile=original
