Is anyone else having this issue? If I give a full left or right on the rudder, after i let go the copter wobbles quite badly on a diagonal axis (i'm assuming its the opposite pair). Did i miss something? This wasn't an issue before with previous firmware, but at the same time it was not quite as responsive. I tried toning down the travel but I found I couldn't arm the board anymore. I suppose the arms could be bent, (i'm using a jakub lunar explorer frame with aluminum arms so it's hard to tell, but if they're off, its not bad at all.
Ideas?
I'm flying an APM2 on a Delrin Tricopter and getting odd yaw behavior in 2.7.1 - it seems like it turns counter-clockwise very easily with only a little bit of stick, and has a bit of momentum that keeps it turning. Clockwise is the opposite, I've got to push the stick quite a bit to get it to turn at all and when I return it to center it kind of bounces back a bit. I assumed this was a tuning issue that I needed to work on - maybe it's not?
This might be a issuse regarding the compass if you are in simple mode.
The compass can be interfered with during flight. If it changes from takeoff then there is a
condition that wires produce EMF to the compass.
This is caused by throttle to the motors increasing their amp draw wires near a adjacent magnetometer ;-)
At the very least, any idea when next firmware release is hoped for? I would really like to flash the fix on there but im not sure where to start, if someone would kindly give me an idea...
I suspect a tweaked frame myself, but if it's off it's not off by much. Regardless, knowing that there is a fix, i googled as much as I could and couldn't find the links to the current revision. Any chance i can bug one of you for the link?
Jason has been working on this.
I personally believe that it might have a lot to do with uneven thrust vectors (tweaked frame, twisted motors), as you are only the second person I have heard mention this.
Yes, this has been identified. The current trunk has a fix in place. If you want to grab that one you can or wait until the next point release.
Jason
