I am looking for feedback on using the Sony RX100iii as an aerial mapping camera. Currently we use the Canon SX260 with occasional blurred shots and lower-res/quality than we would like. The RX100iii looks like an excellent replacement but I am hoping for some feedback before making a purchase.
Thanks!
Sony RX100iii is a good choice for ariel mapping.
I also have a Sony RX100 M3 which I want install on a drone. If anyone has done this could they advise on what 3 axis gimbal that would suit this camera?
Walkera make one for the Mk11 version but it needs to be modified to get the balance correct. Can be controlled with a device from LittlesmartThings.
Walkera have a very annoying habit of loctiteing everything so the heads of the small screws beak when you try to remove them.
Totally over the top. Setting the PID Values is also a bit tiresome. When you finally get it to work it does deliver great footage.
Seen a lot of really good reviews and videos using this one:
TP100A 3-Axis Brushless Direct-Drive Gimbal
Shawn
Thanks for the link and it looks exactly what I want. Even has photos of the RX100 in the gimbal!
The Sony RX100 M3 is a great little camera and I am awaiting delivery of a Stratosnapper 2.
Can I ask what frame would be good to carry this gear? I was looking at Lumenier QAV500 V2
http://www.lumenier.com/products/multirotors/qav500
but any other suggestions would be appreciated!!
If it were me I would want something a little more beefier than that frame. You are going to need to be able to hang the gimbal underneath it so something with some landing gear and clearance is necessary. Also depends on how much flight time you want. I always use eCalc these days to add everything up and make sure I am using the best components for the purpose.
Sounds good advise and I will visit eCalc.
Thanks again.
@Reuben @Esben
In the body of my QX 100 i see 5 pins.
I've receive an interesting mail tonight from 3DR, look at the page of 3DR Instagram.
You can see QX1 under Iris+, very good job!
However the weight of QX1 without lens is 216gr. Too heavy for me.
But the QX1 seem to be trigger by USB, maybe QX100 too.
Sylvain
You can control both the QX1 and the QX100 via WiFi interface. I have successfully flown the QX1 on a fixed wing triggering over WiFi with an interface that I designed and wrote. This interface will allow you to control all aspects of the camera including shooting mode, ISO, F Stop, Shutter Speed, Zoom (if a power zoom lens is there), etc. You could potentially also transfer the images in real time to a ground station. I have however not tried that because currently my RC is on the same WiFi frequency so with small transfers like just the shooting commands I get no interference. But I fear transferring images over WiFi may introduce more interference. TBD though.
Hi Jamie, that sounds great! how did you manage to control the camera? Would your method also work for the much cheaper QX10?
1
2
3
4
5
of 6 Next
