Hi to all!
I have to map a large area and I would like to know if somebody use an automatic method to split a large area into small areas for mapping based on the max flight time of the plane/multirotor.
The idea is to get small poligons based in a big one.
Thanks in advance!
Best regards,
Mauro.-
Yes, that should be an interesting feature to add to Mission Planner / Survey planner : max flight time. A software solution to propose an optimum cut in several flights for a given large area to map.
I am currently determining my max flight time for my Iris+ in loaded condition. So far my conclusion, with 15 min max, is that I will have to do manually this exercise quite often. Good point Mauro.
Pascal
