Suggestions?
Building an x8 octo copter. Anyone have any suggestions on the type of motor (Brand and KV) type of props? (12in / 14in ) that would work best on a 380mm airframe running a 5500 mha batt in the center and a gimbal on the front? Just a gopro gimbal (brushless motor drive)
 Im really going back n fourth with 700kv to 500kv ect.  Its my last stumbling block on my order.
  • well if your going that small your still you need 1000kv 1800kv 8x4 props
    suggest hobby king D2822/17 1100KV BEST for that size you will need 2 3s battery
  •  380mm frame will limit your prop size. This will guide you towards smaller props and higher kv motors, at the cost of efficiency/flight time.
  • how about nether getting some good flight times from 3S batters 15x5 CF props so-pose to run on 6S if you do not want to use large props go with hiyer KV motors.
    SUNNYSKY V3508 380kv I will try X4410S as well but all nice less expensive than RC Tiger motors.
