Tethered UAVs are used for long-term continuous operation. The driving motor is the core part of power, which must work within the rated power range. However, as far as I know, the empirical value of the lift/power ratio of rotorcraft generates about 5 ~ 10 kilograms of lift per kilowatt of power, but the power-weight ratio of the tethered motor is less than 1 kilowatt/kg. Will such tethered device affect the charging of UAV in the future?
3691382759?profile=original
  • The effect of the tethered device on the UAV is from the output voltage, the motor power of the tethered device is not affected.
  • First of all, it is important to understand that tethered motors drive tethered operations. Drones run on motors. It's not the same.
    Have good time
