  • Hi Karsten
    thanks for the pictures, I'm trying to configure two XRF modules as you suggest, but the connection between APM and Mission planner stop work after some seconds. In the debug windows I've a lot of crc errors.
    Do you have modified the XBBO boards or have you changed any parameter in the APM firmware?
    Thanks!
  • I notice they have advance advertising for a URF.
    http://shop.ciseco.co.uk/urf-radio-module-and-serial-inteface-via-usb/
    No information, but it looks to be an XRF with built in USB interface.
  • hi all,
    fell off the radar again with work!
    yep, work they do and quite nicely as well
    you need to change the baud rate on them and that is as easy as hell
    but apart from that they are sweet!
    range so far is 2500 meters with stock antennas in a low RF site so i will come back with range tests
    when i conduct a few more "REAL WORLD" tests
    cheers for now
    Mitch
  • yes it works :-) ,
  • interesting, but work it like xbee with more distance ?
  • have you tried them yet?
