Hello, i'm using APM 2.5 with ArduPlane 2.76 & i want to trigger a camera shutter at a certain waypoint by using DO_Digicam_Control or maybe DO_Set_Servo, but the condition is I must have one switch on my Futaba remote set to high, only then the servo should trigger otherwise not.
So basically i need to check for the pulse at that input channel, then if its high, trigger the servo for camera shutter when the plane reaches the desired waypoint.
How can i do this?
I can modify code given the right directions.
  • Hi Vaibhav,
    Did you solved this triggering setup yet? I am also got this problem too...
