IMO the Turnigy outshines all others by the Open Source nature of the firmware. There are destructions and guides, as well as no-soldering-installation kits availible to add a usb interface and upload new code.. if your comfortable with building a ardu-anything, you can handle adding new firmware to your Turnigy!. New code brings out easily programmable APMega switches and dials.
Not sure if this is mentioned elsewhere; I'm using the Pot knob on the front of the 9X transmitter as a mode switch. I used a red and black marker to mark the alternating arcs/zones for the 6 modes (0-5) around the knob. This way all modes are in one spot. Works well for my needs
Hi
I hope this helps...I dont have an internet connection at home... Using a blackberry with the BIS... Typing takes forever..
Anyway...
Enter the menu( It is important to note that enter needs to be pressed to save changes made in menus)
1 Go to the AUX-CH menu
2 Change CH-7 to HOV THRO
3 press enter then exit menu
4 Go to PROG MIX enter mix1
State ACT
Master AUX
Slave FLP
Offset 000
Uprate -100
Dnrate 000
SW NOR
5 Save this by pressing enter
6 Go to PROG MIX enter mix2
State ACT
Master AUX
Slave FLP
Offset 000
Uprate 100
Dnrate 000
SW ID2
7 Save this by pressing enter
This setup leaves two extra channels open for use... These can be set in the AUX-CH menu
( Just take care in selecting the right AUX in mixing as 2 are available)
If you need help... Just shout...
Hi, if you guys need help with the programming of the 3way I can help.. I use a turnigy for my uav... No soldering or anything.. Just the right mixing of gear and aux or aux and aux or flap and aux.. Easy to do!
Firstly ... the Control Mode Switch
has anyone worked out how to program the Tx to create a good control mode switch?
I've looked for and failed to reprogram the 3 pos mixing switch.
OR have you replaced one of the trim pots with a switch ? Love to know the part if so.
http://rcav.posterous.com/programming-an-ardupilot-mode-switch-for-...
Anyway...
State ACT
Master AUX
Slave FLP
Offset 000
Uprate -100
Dnrate 000
SW NOR
State ACT
Master AUX
Slave FLP
Offset 000
Uprate 100
Dnrate 000
SW ID2
Gerrit
Space available 31 x 31 x 110 mm (note 31mm H and W are close to absolute max)
Option 1: 2 pack cylinders
Rcgroups forum has notes that a 2 pack 2400mAH Lipo pack will do the task and give 8hrs plus flying.
http://www.rcgroups.com/forums/showthread.php?t=1035575&highlig...
Available in US and others at http://www.dealextreme.com/details.dx/sku.20392
Au http://www.ledcentral.com.au/index.php?page=shop.browse&categor... UltraFire Au$16.50
Au http://www.gadgetsdirect.com.au/index.php?main_page=product_info&am... TrustFire Au$27.00 incl post
Discharging and charging protection circuitry built-in.
This option seems to need soldering of connectors on to cells - is there a safety issue?
Option 2: 2 pack rectangular - normal rc shape
Like this 850mAh one:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=...
60x31x16mm
Anyone had experience changing over to Lipo's?
Anyone done soldering on a 2 pack lipo?
Thanks for any advice.
Thanks in advance
Brett
