I'm using Planner 1.1.14 with a new APM2 board. Win XPpro and the Atmega2560 inf driver file from the repository.
Planner loads and verifies the 2.27 firmware but it does not connect to the APM2. I have used Putty and it does reset the APM2 on connect and I do see packets with mixed binary/alpha content (presumably MavLink).
When watching the APM2 board, it does not appear to come out of reset after Planner opens the port. Since the reset step works correctly with Putty, it seems as though Planner is holding the reset line for some reason.
Should I add this as an "issue" ?
Thanks.
My APM2 also can't connect using USB. It can update firmware fine though.
For me the new mp fixes the problem for 99% I still have sometimes the MP won't connect and the lights won't flash. After taking power off en puting power back it will be fine again.
I am having this issue also with apm2.0.
Michael-- I just downloaded version 15 and tested it here. Unfortunately it now seems to hold the APM2 in reset regardless of the state of Reset-on-Connect. Planner 14 still works without Reset-on-Connect checked.
Thanks for your updates, I'm going to look for an AMP2 blog since this may or may not be a Planner problem.
Just tried it again and here's what I see happening-
1) Insert USB to APM2 board. It powers up, the red, yellow and blue status leds are active, the GPS led is flashing and there is TX activity on the usb port at about 2hz.
2) Click Connect from Planner. All APM2 leds (except GPS) go out as though it is in reset.
3) The Planner connect progress box appears and counts down to "0". I see periodic USB RX activity but no other leds are active on the AMP2 board.
4) The Planner connect progress times out and at that point there is USB RX and TX activity. Planner throws an exception about not seeing heartbeats.
5) When I close the exception message box, APM2 red, yellow and blue status leds come alive and there is again USB TX activity. APM2 appears to start up normally.
6) Open the port with Putty terminal emulator. APM2 resets, I see the startup header and then mixed binary/ascii messages about initialization.
As a cross-check, I just used Planner 1.1.14 to connect to an installed APM1 (red) board in a flying plane. It came up and connected promptly as it always has in the past.
The problem appears to be on the APM2 (purple board) side so I'm going to post a message there, too.
