Hey, i want to report a problem with the GCS. I have a APM with IMU and MediaTek? MT3329 . I cant get a GPS Lock.I upgrade the gps to latest firmware.From telemetry i read 8-10 satellites, but no GPS Lock. The leds were steady red and blue light.I disable (or enable in Mediatek v1.6) any heartbeat configuration but nothing. The same problem i found with APM Mission planner(latest version). I test with Qcontrol and GPS Lock looks fine.
Any help would be much appreciated.
Thank you in advance,
Nikos
  • Hi Happy K and Bertrant ,  today i decide to test old versions of HK GCS .
    So after many test , finaly i setup the version 1.2.39. and observe the followings
    1. When i start up with the auto mode enable , the GCS ( with 4 sats) display the cordinates .
    2. When I switch to manual mode, and restart the program ( without to turn off the APM) the readings are normal.
    3. The flight instruments has normal display.
    Finally i test the Qground Control , with the same sequence ( auto and then manual mode) and the readings and GPS was Normal.
    The battery for both tests was a   4.8 V Nimh fully charged.
    I try again with latest version of HK GCS , but nothing happened
    I want to use the Happy Ks GCS, because is light and simple to use
    Any more help would be much appreciated.
  • Hi  Bertrand , yes i use a 4.8V NiMh batt. What type of Lipo you use ? .  I try with 800mAh 3S1P with UBEC @ 5Volt , but still nothing .
    Happy K, i use the xbee@2.4Ghz.
    So can i connect the UBEC @ 6volts ?
