Unable to retrieve logs
Hi Guys
I'm pretty new to APM2, so don't be surprised if I missed an obvious step.
However, I set up my APM2 and was able to go for a flight (not without some issues, but at least I got Loiter to work on my ICON A5 while flying off the water).
I want to retrieve the logs from the APM2.  In MP 1.21 mav 1.0, I go into terminal and log download, but I get 'error opening com port'.   While the icon in the upper right shows it as not connected, the terminal actually is.
Show settings works as does tests and radio setup.  It is just the Log Download that doesn't work.
If I go into the CLI, I can see the logs and dump them (I am trying to figure out how to actually capture the dump).
Any ideas?
Mike
  • I have the same issue.  If unplugging and replugging the APM2 does not solve it.  I close Mission Planner and try again.  I am not sure but I think Kasperksy virus protection plays a role.  In the worst case, I reboot the computer.
  • I'm getting the same error "Error opening comport" if I already connect mission planer with APM2 (through 3DR radios) but if I don;t connect first, and just hit log download you can see what is happening in the link bellow, I waited about 10 minutes but no logs appear in that list :(
    http://prntscr.com/i93yo
    I tried Per Elofson's solution but dod not worked either. Also an intresting note at least for me, while the Log Download window is opened in the Link Stats window the quality drops to 0 or NaN and also lost packets start increasing, like in the screen show bellow
    http://prntscr.com/i94q5
    In the bellow screenshot the Log download window is closed and the link seems to work just fine
    http://prntscr.com/i94wp
    PS . I instaled the latest firmware a few days ago, 2.8 but don;t know if this is an issue with APM2 or with mission planer as bouth ware updated recently. It;s been a month or so in wich I did not used my copter, but now a week I received a few parts and started again playing with it.
  • I'm having the same issue,
    " 'error opening com port'.   While the icon in the upper right shows it as not connected"
    I just updated to 2.5 and it worked before that.
    I just tried another approach:
    Unplug USB
    Start Missionplanner
    Navigate to "Terminal"
    Connect USB
    Press "Connect"
    Press "Log download"
    That worked for me.
  • I am also new to all this APM stuff, and sometimes have a similar issue. What has worked for me is to unplug the USB cable from the laptop and plug it back in. Seem that the mission planner gets confused about the connection sometimes when going to the terminal screen.
    Also, I sometimes seem to have problems if I plug the USB in the computer first, seems to work better if the cable is connected to the APM first.
