I need a bit of help here, I am attempting to update the PPM encoder on my APM 2.5 following the instructions here in the Arduplane Manual.
I have downloaded and installed Flip 3.4.7.112 using all the default settings and have connected, shorted, and reset my board as per the instructions. When I attempt to connect to the ATMEGA 32U2 device via USB I get the following error messages:
I've tried a reboot and I have tried uninstalling the program, re-booting and re-installing but I keep getting the same error.
For the record I have tried both the download link in the instructions from the drop box (link is broken at this time) and I have downloaded it direct from the Atmel web site (same file). I am using a Windows 7 Professional 64-bit machine and have checked all my drivers and updates.
Anybody got any suggestions?
Nathaniel ~KD2DEY
I've been dealing with this for days.. It all started when I tried to install new firmware via APM Planner 2.0.18 and it told me it couldn't contact the bootloader. Subsequent googling led me to forums with information similar to this one.
I've tried Ubuntu 14.04, Windows 10, OS X 10.11 and even a couple of virtual machines to get rid of "AtLibUsbDfu.dll not found." So far no luck.
In device manager all I get when I "reset" the ArduCopter (by connecting the two pins w needle nose pliers) is the sound of a usb device being disconnected and "Ports (COM & LPT) > USB Serial Device (COM3)" goes away. When I remove the pliers that same device shows up again, nothing changes with flip because I still hear that the dll is not found. It's troubling that I don't even see the ATMega device. Maybe my board is fried.. Any ideas?
I can't get it to work on 64-bit.
OK for anyone who is interested I figured it out and was able to update the eeprom. What you need to do is update the device driver AFTER you boot the APM board and install the jumper and reset the Atmega32U2 (as per the instructions).
Once everything is working you should be able to connect via usb and see a screen like this:
Then after the update:
That's it no big deal! We might want to update the instructions for updating the PPM encoder to reflect this step updating the device driver.
Nathaniel ~KD2DEY
I'm pretty sure this has to be in 32bit of windows. I can't get it to work in Win 7 64-bit. So I'm installing XP 32-bit in order to get the driver to work.
Pain in the butt.
This error message happens because you are using win 64 bits and flip has published a known bug on 64 bits. There is a workaround on the site of flip but i do not remember what that is.
Or alternatively upgrade from another PC which does not run a 64 bits version.
Cu
Hugues
