Hi EveryoneGot the ArduPilot board put together, but when I tried uploading the code I get the following error:avrdude: stk500_getsync(): not in sync: resp=0x00avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51After some research, I have come to beleive this may be a bootloader issue, but I'm not real sure.A little more info, I have reset the board, and afterwards I get a fast blinking blue LCK light.Any help would be appreciated.Thanks!
I have found I cannot load code without the shield attached unless I do a workaround not mentioned in the tips section. The moment the compilation is finished, I hit the reset button. Then it uploads properly.
