Hello guys,
I bought a Power module to have information about power consumption displayed on my OSD,
Unfortunately I bought one without the BEC daughter board so instead of supplying the 5v out for my APM it gives me the LIPO out voltage. I haven't tried to plug the VCC and the GND to the APM, I don't want to burn it.
The power port is made of 6 pins:
Inside of APM
-- GND
-- GND
-- V ?
-- I ?
-- VCC
-- VCC
Edge of the APMboard.
I guess the V and I pins are for the "information" and the GND and VCC to power the APM board, no?
So I've tried to plug only the two middle pins I and V but it won't work, Have someone succeed to use this kind of power module, I can power the APM with a separate BEC via the power port (on VCC and GND )maybe?
My power module:
I you have a 5v BEC you can connect it to the APM via this port.
But be careful there are two pins for the VCC not 1, just test with a voltmeter before connecting it!
I hope it would help, I didn't get your question with the lead and analogue inputs, my english is poor.
That is also my dilemma, I don't trust the figures that are coming from the multi pin or the solder pads on the back.
Thank you!
I 'm happy to know that I can use that module! I'm gonna use this BEC:
Thanks for you help I gonna try that today!
Its working!!!
Cheers!
