What can a visionary man do, who holds the whole vision of a craft in his head, but is not able to draw two parallel lines. Ask for help : ?
Good technical 3D drawing skills are needed for:
A Saucer/Frisbee shaped vehicle which turns by magnetic levitation and is held focused via strong gyros.
All fans are electric and solar powered. Partly levitated by helium.
Do not hesitate to ask and contact me!
Greetings
Lars
Dear Mr J. Smith
Thank you for hearing my prayer, and I appreciate your response very much. Have just requested friendship
Am so sorry I did not respond to your question earlier, but I had to do a long search to find my own topic again in this forum.
So to make it clear, what this is all about
The end goal is an enormous hollow helium filled frisbee shaped craft, with crew sitting in the center on a round sofa turning their face outward. They will be steering via a simple i pad device like done with a drone. There will be three separate steering systems if one of them fails. Radio, Infrared and of course af physical.
I imagine that even the sofa is blown up with helium, like most of the rest of the vehicle.
Imagine an iglo tent which is only made of two telescope tent ploegs or extandable sticks which are bent. (the solid part which holds up the tent up) Actually i consider these to be adjustible so you can extend the outer part of the vehicle, and also they will help the vehicle when it lands, like the legs of a landing insect bouncing.
Now the basic idea about the craft is placing the 4 fans in between the center and the radius of the frisbee craft, and making each of them tiltable.
The size of the vehicle has to be fairly large, so that most of the energy is mainly concerning balancing the craft and bringing it forwards.
Now I guess this is enough for now
Hope you are still with me
Greetings
Lars
What does this visionary man have in mind for the project?
Hi Michael
Hope the answer below will help your curiosity?
