WHAT IS A BROWN OUT?
So I think my octocopter had a brown out, but the question here is if I did have a brownout is it the autopilot or the power module? And how do I have out in the log files?
Thank you for any help.
  • Brownout is lower-than-spec-voltage state at which a cicrcuit cannot mainain normal operation, an microcontroller/processor usualy have a internal brownout detection, which pulls down reset while voltage is below minimum - to ensure proper start, and not unpredictable corruption/crash.
    If you see the log suddently stop, and maybe then a new log start (reboot) even before hitting ground - that can be a brownout.
     in short: your +5v is not reliable if that happens - or there was a overload.
    • yup, sometimes you can spot it looking at the Vcc log in the log files if your flight Arducopter based controller supports it (I.e APM and I assume Pixhawk, VR Microbrain doesn't). Look for voltage dips or a generally low voltage.
      Although the auto log analysis tool will show a brown out error if your power system is fine but a cable got yanked/Failed, as the log file will be truncated (not complete).
      Stu
    Its your power system not being upto the job
    • so i need to replace the power module?
