Hi all,
I've been out of the game for a few months and just got round to installing 3.0.1. Testing it out today in the back yard it seemed to work fine until I switched to Alt-Hold. In Alt-Hold mode the just kept wanting to climb until I switched it back to stabilise.
I've attached logs from two of the flights where this has occurred. Below is a graph showing the behaviour (taken from 2013-08-10 00-16 1.log). For some reason the WPAlt keeps increasing while Alt-Hold is engaged, but I can't figure out why.
3691047720?profile=original
I am running an APM 2.5 enclosed in the 3DR case (complete with foam covering the baro). My sonar is mounted as far from the ESCs and BEC as I can put it, and has powerline filtering.
I have the APM mounted on squares of anti vibration foam at each corner. I believe the vibrations are within what is acceptable (IMU logging is turned on - see for yourself). Finally, not that I think it affects Alt-Hold, I get around 40% interference when running the compassmot test.
If someone could take a look and let me know what's going on here it would be much appreciated.
Thanks,
Chris
2013-08-10 00-43 2.log
  • have you set THR_MID? if your THR_IN is graphed with the axis on the right, then it looks to be higher than the default 500. That would cause the copter to climb in alt hold
  • Tried without the sonar?
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
