After rebooting, though, I could give rudder input and 2 motors would spin even though the Green LED was solid (indicating the "unarmed, safe to move" condition). Stranger still, I repower the board an hour later, and the heli initializes and I am able to arm it and the ESCs all work again. I even test hover over some grass. I land a bit hard and then the problem reappears.
Now at home, however, I cannot re-arm the board. Configurator does not show any Tx inputs. I know the Rx is good, since I switched it out with another known good one and double confirmed using a standard servo. My sensors all respond in Configurator. The board boots normally (flashing R G B, then solid Green).
I just do not know which board is damaged? I'm assuming it's the lower Mega board (since it's the one with the servo headers, plus it's cheaper), but want a more informed diagnosis.
Was fun while it lasted :^(
If you have those bullet connectors between ESCs and motors, make sure to check they all have good contact.
In my case I found several of them were rotating freely also when mated, causing bad electrical contact. I soldered them up solid.
