I've been using MK electronics for years now for my multis but have found Pixhawk and Arducopter to be a far superior product in many regards.
I want to replace all of my MK stacks with 3DR pixhawk.
My question is this:
Should I change the MK Motor controllers over to ESCs or can I EASILY use the MK BL-CTRLs with the pixhawk?
Thanks in advance!
That being said, I do have a BUNCH of MK boards for sale :)
  • Hi Chris, personally I'd stick with the MK motor controllers, the firmware is very solid and has far more diagnostic reporting than 95% of the BLESC's used by masses. That said, if you are looking to offload a few MK boards then your post has sparked my interest :)
    • How do I connect the BL-Ctrl to the pixhawk?  I know via I2c but how do you program, etc....
      • Easy, you just use the MKBL Ctrl  PWM out port and not anymore the I2C. I tried the I2C PX4 version before and it's not as perfect and as simple as using the PWM port. The speed of the Bl Ctrl is 500Hertz.
        Hope it help
Aug 25
